Compfusion Mounts
N
Newfy9
New member
Guys when I pulled my mounts I didn't notice how there where setup. There is a thick cup and a thin one. Which goes towards the engine.??
Wish i could help you out.... But I just don't remember and it's been about 7-8 months since I've had mine out, and even then I had to dig up the instructions to see how they went back together. I've been trying to find those instructions for you but haven't had any luck.
This reminds me that I have a set in mine that are shot, after very few rides, so I need to either replace them or change them out to stock. Did you get new replacements from him or are you re-using the ones you had?
Edit: Just found this snooping through the Useful links thread, posted by Guido...
CompFusion Motor Mount Instructions;
Most of the procedure for installation can be found in the service manual for the correct model of sled; however, it recommended that a Polaris service technician with the CORRECT tools perform the installation due to the complex nature of the CFI engine.
Remove engine as per Section 5 of the Polaris service manual.
Remove the front engine support (Part #5134872).
Disassemble the support/mount assembly retaining the Torx bolts for use with the new mount.
Upon final assembly it recommended to use high strength threadlocker on ALL fasteners to prevent loosening from vibration.
Assemble the new aluminum mounting plate to front engine support using the Torx fasteners removed in previous step and the supplied nuts.
Using a drill press drill out the remaining 4 bolt holes and install the supplied Torx bolts and nuts. The short bolt should be placed inside the steering cutout.
Assemble the engine support to engine using the supplied pucks/washers. The thin washer is to be put towards the engine with the thicker washer inside the engine support.
This is important for proper engine alignment.
Make sure the rubber and aluminum components are very clean prior to assembly. This will aid in bonding of the two pieces.
Using the supplied 3/8 x 2.25” bolts torque the support assembly to engine @ 40 ft/lbs. Note: Do not reuse the OEM large washer. It is not necessary and may in fact cause an issue with the bolts threading into the engine case.
Reinstall engine into chassis, preferably using new replacement bolts at the cross-member ends, and check center distance and alignment. It is highly recommended to replace the torque stop as well as the factory update kit urethane washer on the PTO rear mount if worn. This update is very important to prevent side-loading of the front mounts.
Does anyone know off the top of there head what the torque is for the aft engine mount bolts. I can't sem to find it in the book. or is it just standard torque for those size bolts
I don't think they ever really call out a torque spec for most bolts and just go by standard bolt torque. There are some exceptions like in the above post.
