Yes. I hit a tree with my throttle block...block slid into my grip and stretched the wires out...ripped hadwarm wires from plug....and unplugged my thumbwarmer wire frombharness. P1600 appeared on screen shortly afterAnyone else lose their hand and thumb warmers and get these codes?
My codes came after hitting the kill switch and pulling back up real quick, cruising at 50mph.
For me, shut off sled and start it back up. Still working to this day.So.... What was the fix?
Follow the wire harness from the bars all the way to the engine. Gotta have a short somewhere.Swapped bars from one sled to the other and the codes still are there..
Hi E-Storm did you ever solve this issue? My 2021 Riot is doing the same exact thing.I saw a thread on here somewhere that shifting to reverse and forward again clears the codes and gets the heaters working again, and that also works on my sled but doesn’t permanently solve the issue. In combination with this, the LED headlights are very dim and erratic. Anyone else experienced this issue? I’ve chased the wiring harness, swapped voltage regulator, stator, ECM, and cowl w/ headlight assembly without any results.
