Clutching M1000 Turbo
T
Turbo Monster
What are you guys running in your primary for a spring. Mine engages at about 3000 rpm. Sounds kind of low. My Alpine Turbo engages at 4500 RPM.
It depends on how you like the engagement. Most of them that we set up engage around 3800. You can run them lower than that, but to me they feel sluggish in the trees when you have a lower engagement.
What spring would a guy need. Its got a bad bog out of the hole. But if you get the RPMs up it great. Maybe I'll start with a new it,s the original one. About 700 Miles on it.
That should make a difference, what kit are you running, even that low it should still pull pretty hard unless its holding it down there for a while before shifting.
Reeds are not double stacked.They are original and only have 400 miles on boost.The clutching is from Twisted. It came a complete kit.
