Pitch the factory helix, ramps and primary spring. Go back to the 08 setup and fix the real problems. Mine runs whatever target rpm I choose with clutch temps in the 120 degrees F. range. It runs within 150 to 200 rpm from pack to powder and actually builds track speed....unlike the POS 09 setup. Just run a gram or two less for 8k and up. JMO.
BTW the 08 setup doesnt work too well till you take care of a couple big issues. But it works better than the 09 setup in the hills once the sled is fully broken in.
What exactly are the differences between 08 and 09 clutches
2008 clutching
short hollow pins 10.9 gm--at 8000 feet up
413 ramps
160-320 primary
straight 42 helix
JUNK
2009 clutching
longer pins 12.2 gm hollow- should have the2008- shorter pins for our elevation
441 ramps
200-320 primary
43/47 reverse angle helix
JUNK
secondary spring is the same
JUNK
I didnt think the clutching in my 09 was that bad. 250 miles and havent blown a belt, 40-45mph track speed on a good climb, very responsive. The only thing I would like to change is to get the track speed up a little, and bring clutch temps down just a little. I can put my hand on my clutches, but not hold it there after some hard riding. Im not vented yet either though.
So if things arent that bad, a guy shouldnt have to change too much should he? I was thinking of trading ramps with a buddy that has an 08. That should be a win win for both of us shouldnt it? Then putting a 160 320 primary spring in it and gearing it down to a 20 tooth on the top. Any thoughts on this setup?
