clutching help-yamaha
neverenoughsnow
i need your help yamaha guys. i am running a 99 mm, bored over to 800cc, race port and polish and heads from rollform racing. yamaha racing triple pipes. i have the sled down to 455 lbs. and i am running a hi-tech clutch setup with a thuder shift kit, spinning a 151x15x2 track. what are you running for primary and secondary springs, and weight in primary. i am running yel/grn/yel in primary and i think i need to drop down, i am trying to get the belt to run up on the primary higher, i am within 1" but it has dropped my rpm down to 8500, with lighter weight i was at 9500. starting to pull hair, help.
gearing
i believe i am stock geared, with 8 tooth extrovert drivers. i can check tomorrow. when it had a wore out primary spring and before motor bore and port it ran up the mountain at 45mph. cant tell you mph no more i threw it in trash
