clutching help ! 13 pro rmk 600 with a 155
just looking to see if any one has any good clutching set up for the yooper !!!!
i have a 13 pro 600 with a 155 with a can only would like some more low end .... ride only in the woods all day
thanks for any help
just looking to see if any one has any good clutching set up for the yopper !!!!
i have a 13 pro 1600 with a 155 with a can only would like some more low end .... ride only in the woods all day
thanks for any help
Post moved to a more proper area. Should get you an answer a little quicker over here.
just put in a gear down from Kurt's polaris, helped a lot. did clutching from TRS, a user on here.
I have MDS adjustable clutch weights with 110/290 primary spring and love it. Plenty of low end for the trees. I ride the Northern Lower and Upper. I do have an 800 though. I would imagine the clutching be close to the same, just needing a little different combination of hardware in the adjustable weights.
Currently I am running the Hex bolt and washer in tip and drilled bolt and washer in center. I am going to be removing the washer in center as I feel I am a little heavy in weight and 100-200 RPM under where I wanna be.
I will be looking at a Kurts gear down kit over the summer
I've got a '12 600 with 19/42 gears, TEAM Green primary spring, and Carl's Custom angle helix with MTX 68g weights for WI/UP riding. The custom angle helix is a dual angle, which I change up when in WY. Absolutely love the pull and back shift of this setup.
Also running MDS adjustable weights in my 800 with recommended 110/290 spring. Ride between 1800-3000 ft. sled pulls really hard but I also have a camo extreme which grips better than the stock track
I have the same sled, Skinz can. I think the only way you are going to get that low end grunt is to gear it down. Belt drive makes this a little more pricey though.
They are a great sled to play in the trees with!
