clutching for central wa.
What weights for a 15 800 pro in yakima, cle elum riding areas?
Need more info!! A pro rmk, or a proclimb. What elevation, are you an aggressive tree rider or gonna cruise the trails. What if any mods are done, your weight with gear on. Type of track, etc etc
15' BDX 940 Prolite Bikeman BigBore
13' ProRmk Turbo full custom build.
Pro rmk, 230lbs. No climbing any more, just playing off the trails.
If your using stock Polaris, MountainRider05 is right with 62g and let her rip. If your looking for aftermarket, I suggest MDS and 67-68 grams and you'll think you did a pipe and controller. They are the best bang for the buck and a simple bolt on. Big low end pull and gives the pro the back shift it lacks. Call Steve Mitchell at MDSClutching.com and he'll set you up. Full money back guarantee if your not blown away. Can't beat that offer!!
Thanks, I brought this sled in from Id. you'd think I was trying to steal trade secrets by the way local dealers respond when you ask about their setups. I just want stock for now, maybe change to aftermarket later on. Any setup info appreciated.
What do the dealers say when you ask about setups?
I second it, the best weights and tech info on clutching setup is with Steve at MDS Clutching in Ellensburg. I have run his weights since 09 and have his P1T weights on my sled now.
