So since the end of last year every time I take a hard turn in the powder and am under full load my belt slips really bad then finally catches. Clutches are hot to the touch. This is stock 09 Dragon clutching with 10-58 weights. Clutch alignment is very close to spot on, clutch just balanced by indydan. Riding at 10K ft.
Do I need to add more weight or less spring in the primary? My clutching holds perfect 8100 rpms on the flats but bogs down and holds to 7500-7800rpms when turning or climbing in deep snow.
Is my belt slipping a case of wrong clutching or is it snow ingestion from my side panel vents? I am starting to think snow is getting on the clutch since it only slips when or after I get the sled on its side under heavy load. My side panel vents don't have prefilter material on them so I'm guessing the snow is getting forced into them at speed.
I purchased a bunch of prefilter material from SLP to see if that solves the problem, if not, I'll start messing with my clutching.
Anyone else experienced any of this?
