P
piper907
New member
Ok...
I am interested in learning a bit about clutch tuning and I was hoping someone on here could give me a bit of direction.
I pulled the primary apart the other day and cleaned everything, also cleaned up the pins that connect the rollerarms since they were just a tad sticky.
I went riding and tried a whole bunch of clicker settings.
sled pulls GREAT at the bottom end on #3 and the motor seems to pull quite strong to 8100-8300 on setting #6. I ended up riding it on #4 and that seemed pretty good but it will top out at 7800rpm.
It would be really nice to have the low end of #3 but still be able to rev to 8000rpm. Is it possable to have the best of both worlds?
I read a post a while back where someone suggested adding weight till the sled will rev to 8000 on clicker #3.
What is the proper way to add weight???... will larger set screws do the trick or will i need more weight than that.
Please help me with a bit of direction
