You will need the standard primary clutch puller to remove the primary, then a spring tool to hold the governor cup to change the primary spring. (I just use a long piece of ready-rod in the vice with a big washer and a nut....the spring is long so leave about 3" of threads in able to safely release the tension)
For the secondary you need to first remove the shaft and secondary as a unit....not a difficult job....if you choose to leave the chaincase cover on and support the top gear, make sure you don't drop the spacer behind the gear. If you've never done it, just remove the chaincase cover....probably time to change the oil anyways. There's also a 13mm nut on the bearing retainer behind the secondary. With the secondary on the bench (I clamp it in the vice with a rag veeeery carefully as the shaft is hollow), you need a special spring tool that screws in where the belt adjuster goes to relieve the pressure so you can loosen the 4 bolts holding the helix on. Use blue Loctite when reinstalling the new helix.
I was able to get the helix / spring out by standing on the secondary holding the jackshaft. Used some 1x2 scraps to help balance myself while I backed off the torx. Kind of spooky once you get the bolts out - hop off quick or cover your nuts!
