Clutch set up for Pro
spark2
New member
You guys with Carls Clutch kits, I have a stock 2012 Pro Rmk 800 155''.My weight is 195 wet. I will be riding in the area of the Thunder mountain lodge in Cedaredge,Co. I have Carls Clutch kit. Will 60gr belly buster be OK?. Is that area at elev 10000 ft ? Or should I install 58gr Belly busters.
There website says the average elevation is 10,000 feet. Knowing that I would install the 58 gram weights, but bring the 60's if you have them just in case... But I'm guessing the 58 grams will be spot on. Good luck!
