Clutch rubbing on side panel
My proclimb without sucked in panels rubbed... I just made a brace with a chunk of aluminum and it was fine after that. Whats the brace like on the 2018?
The dealer demo I rode the last 2 days has the panel worn right through by the primary clutch.
Wow, needs more strength or support in that area.
Or just put a big rivet like the 13-17's that rivet keeps the plastic safe lol.
Go Hawks!
On my 2008 Ski-doo, I had to stick a piece of stainless steel thin plate on the inside of the panel with 2 sided tape. It got chewed a bit bit saved the side panel. A bit of preventative medicine is required here.
So far this is the only problem I have heard off, It'll be a pain in the rear, but a lot better then blowing motors and cracking bulkheads
Primary clutch rubbing hole in side panel.
Yeah I'm not real happy that my new sled has a hole in the side panel. From primary clutch think it's something that Arctic Cat should fix and warranty! Really like everything else no complaints other then that 350 miles later.
