I burned up my drive belt and can't get the clutch off. The engine is all bound up due to belt winding getting jammed in between the clutch and engine block. I removed the outer portion of the primary clutch and the secondary, but I can not get the inner portion of the clutch loose from the crankshaft. FYI I am not using a puller. Is there a way to get the clutch part off the crank? Anyone gone through this before? I am concerned I have damaged my crankshaft seals with the belt winding. Thank you in advance my doo friends!
