clutch puller ?
edgey
I tried to take the clutch off my 15 rmk with the clutch puller I used for my 07 700 dragon and it don't work so what puller do I need?
Thats strange, my puller works on all my sleds from 2000-2011. Should be the same one right up to the new axys engine i think.
My brother has my puller I used ony edge rmks I'm going to try that one when I bought my dragon it wouldn't work
Yes the Pros are not so deep, you have to grind down the tip of the puller. Just make it smooth and put grease on the tip.
Ever try doing the water trick?? Tilt sled on it side so clutches are up. Pull primary bolt out wrap threads in Teflon about a dozen times. Fill hole where bolt came out with water. Put bolt back in and start to tighten it. Acts like a hydrologic removal. Do it all the time on my doo.
That won't work on a poo the clutch bolt don't screw into the clutch. You would just be squeezing the water inside the crank where the bolt screws into it.
U sure? Another guy in a different said was doing it on his pro?
Well I dug a little further looks like it does work on the pro from reading past posts.
What puller are you using? Pretty sure mine is an EPI but I will double check and its done every 600/700/800 from 2000.5 to 2014. Unless the 15s have a different clutch. And that is everything from the 121" to 163"
