Clutch on a 2010 dragon 800 making noise
Hard to say but you should pull it off and dismantle it to check. At the very least remove the clutch cover bolts so you can see the primary spring and clutch weights.
When was the last time both the primary and secondary clutches were pulled off the sled and opened up... and a spring change?
How many miles on the sled? What kind of use?
Pull both and send them to Indy specialties. They will clean, balance and repair or replace anything your clutches may need.You can download the information forms from their website. They do top of the line work.
Nooby
