T
tard
Well I am down to getting the offset correct on the large list of issues I have found with this sled. (1st time polaris owner, not impressed) Polaris manual says to loosen the 4 lower moter mounts and the 2 torx screws on the mag side (under the skid plate
), move the motor, and re-tighten in sequence. Did this, and the secondary is still about .200 off. It looks like there is a 5th mount (brace) between the 2 lower mounts at the rear upper corner of the primary. Is this to be loosened up as well? Did not see anything in the manual under offset adjustment.
