I got this from Dale Cutler...
”If you decide that you want a higher engagement, then you will need to remove the drive clutch,
then disassemble and remove a shim under your spider to increase engagement. You will NOT be able to just install
a stiffer spring in the new Team clutch like we use to do. This new clutch does NOT respond to instilling a heaver spring
like the old clutches use to. It has to do with the way that the drive clutch was made
in relationship to the center of gravity of how the cam arms sit in the drive clutch. ”
