Clutch broke/stuck
rocks rev
The pri clutch on my brothers 99 powder special is broke and he cant get it off with a puller, any ideas?
if the puller isn't broken off inside the clutch, you can use the hydraulic method, which will work well......get a long bolt that fits the threads, lay the machine on its' right side....fill the clutch with grease, or oil, or any fluid...then tighten the bolt and the clutch will pop off....
