M
hey , just wanted to pass along a vendor I did biz with
he does clutch work out of his transmission shop
. guys on HCS use and recommend him a lot.
http://www.smittysengtrans.com/
this is some of our emails
Thank you
On Jan 7, 2016
11:02 PM, "steve smith" <smittyseng@yahoo.com> wrote:
To balance the clutch is $75, to
remove stock nut, install tube nut and 911 cover assuming it
wont need clearencing would be $30, so $ 105 plus return
s/h. IF I remove spider, reface both sheaves (index in
lathe, cut true then finish sand), clean loctite from
threads, reassemble it would be another $70 which would put
you at $175 plus return s/h, let me know, Smitty
Looking at your clutch, do you
just want the 911 cover installed and clutch balanced? Your
clearences are plenty loose, sheaves look good and you have
it already shimmed, let me know, smitty
Sent
from Yahoo Mail on Android
On Jan 2, 2016
9:34 AM, "steve smith" <smittyseng@yahoo.com> wrote:
Smittys eng
trans3241 bradleyville rdVassar, mi
48768989-213-7434
Sent
On Sat, Jan 2, 2016 at
6:58 AM, jon v
Where do I ship my clutch to ?
On Dec 27, 2015
9:10 AM, "steve smith" <smittyseng@yahoo.com> wrote:
I need clutch with
weights and pins out but a spring in. Some balancers ( like
fett brothers and micro belmont) spin clutches on a
converted tire balancer to 400 rpms and 1 gram, we spin
clutch on a arbor at low speed then high speed (3200 rpms)
and to 2-3 tenths of a gram
Sent
On Sun, Dec 27, 2015 at
1:29 AM, jon v
do i need the clutch loaded with spring
and weights to balance?
so just ship
my clutch to you for service? whats different about high
speed balance vs a normal spin type
also would need a Hercules helix 36^ and
spring for secondry
On Sat, Dec 26, 2015 at
1:47 AM, steve smith <smittyseng@yahoo.com> wrote:
I keep 911 kits in stock, they are
240$, high speed balancing is 75$, if i install/trial fit
etc its a little more. I dont have a good way to machine the
moveable secondary sheave if you are looking to get them
recut as my 8" 6 jaw chuck doesnt open quite far
enougj. Let me know, Smitty
Sent
and this is my clutch after.
opps sry pics are to large ..
anyways im pleased and thought some others might want to know of his service and how it is different than other shops
Thank you
On Jan 7, 2016
Sent
On Jan 2, 2016
Smittys eng
48768989-213-7434
Sent
6:58 AM, jon v
On Dec 27, 2015
I need clutch with
Sent
1:29 AM, jon v
so just ship
spring for secondry
Sent
