Wondering if there is a way to check the clutch alignment without the tool? I was thinking with all the smart wrenchers we've got around here that someone may have a way to check this.....
why not let it float, its always in alignment as it shifts?easy done on the team
Yes I can read a manual also, I was stating how I do it, never had issues doing it this way.
I didn't intend to offend you, your way works just fine IF you have, which you do, a good feel for how its supposed to be!
I was merely suggesting that if you're having problems with abnormal belt wear it's probably best to do it "by the book" to rule out the possibility of wrenching errors.
For what it's worth, doo's race manuals in the 90s had tested float for alignment, and found that under power a floated secondary does not move under power (it binds).
With that said, I had lower temps on Revs with a floated secondary (and TRA), but float wasn't excessive. So, I assume some float is good, but like ice cream, too much makes you slower.
Hey Mike, I own the Polaris SPX alignment tool. If you feel like coming down to the south end, I'd be more than happy to check it for you. I have had excellent results with it after adjustment and every '12 and '13 Pro I have checked has been out in offset of the secondary.
Let me know. I still owe you for you sponsoring my daughter with you goggles.
