Hatchers if you are looking for the Arctic Cat recomended alignment spec for the sleds it is
1.655 offset bar for the 07-09
and
1.507 offset bar for the 2010
from what I can tell they have machined the secondary to allow it to move farther in.
As the basic set up of the sleds has not changed I think they think this is a better set up. But you can't use the new measurement without modifying the secondary on earlier models or use the new secondary.
Woody
so is this 1.507 a total gap offset? If im thinking right this would actually be .075 in or out right?....if so, the 2010 sec is .080ish in from previous years
and .080 is ****in huge in my eyes
So I though I have been reading lately that the 09 's should align to the 1.507" offset too. Is that correct?
Hope so because I just bought that bar...
The correct bar to use is 1.507. Any sled with 10.4 secondary. 1.655 will eat belts.
What he said and if you need to go in really far make sure you run at least one .030 behind the secondary to keep it from hitting the reverse drive case at full shift.
Longer belt the secondary needs to go in. If you look the 10" secondary had 1.375" of total shift the flat edge left on the secondary was .25" now add those numbers up. With the 10.4" it de clutched the sled and the total shift is only 1.25" now needing less off set and the clutch needs to be moved in. .25" and 1.25" is 1.5" and the extra .007 is for the deflection with a new belt. AS the belt wears we need to keep moving the secondary in.
Cheers Don.
The one previous was a 1.6 I think
CLUTCH ALIGNMENT BAR
(p/n 0644-496)
When checking/adjusting clutch offset on all
2010 model snowmobiles, Clutch Alignment Bar
(p/n 0644-496) must be used. This alignment bar
has a 1.507 in. offset and is the appropriate tool
for the following snowmobiles:
• 2006 ZR 900 Model
• 2006 Firecat Models
• 2007-2009 F-Series Models
• 2007-2009 T-Series Models
• 2007-2009 600 Sno Pro Models
• All 2010 Models
