Cleaning Injectors
sonday_2
Here are the wires to clean your injectors using a 12v battery and a compressor..Found the wires to do it so you dont have to find them just count..
Upper PTO red/blue #5 and green/white#5
Upper Mag red/blue #5 and yellow/white#7
Lower Mag red/blue #6 and soild yellow #8
Lower PTO red/blue #6 and soild green #6
Using a 12v battery... The injector have to open to do this..So you just find a thin wire that will fit into the connector from the ECM and hook up to a 12v battery..You will hear the injector open with a clicking sound. From there you can use the air compressor..
Thought I would share it
I would recommend taking them to a company such as DR.Injector and they will flow test them before and after cleaning. This is important so that you really know if something was wrong and the problem got repaired. Your injectors get cleaned in an ultrasonic tank and it only cost $20.00 per injector.
Thanks, Cam-shaft.
