What's the best method for cleaning out the corrosion inside the connections?
all of my smaller plug connectors are visibly corroded back into the wires. is there a neutralizer that can be sprayed in the connection before you grease them and reassemble?
fwiw, all the relays had a pretty green patina on them too. too bad the shop didn't notice it when they were in there at the end of the season. on the bright side, i did find a few connections that weren't corroded.
