Chromoly Pro Ride Flat Lander Drive Shaft on Quick Drive Pro
J
jhillam
Does anyone know if a chromoly drive shaft from the flat lander Pro-Ride fit on a Pro RMK with Quick Drive? I have a Pro RMK I am wanting to put a 2.52 pitch track on and I can't find 2.52 pitch drivers for the Quick Drive aluminum drive shaft.
John
Yes you can use the Hydro-formed steel shaft on a QD equipped sled.
You can not use the glued Aluminum Large hex shaft on a chain case equipped sled because there is no provision / place for the seal to seal, nor room to install the old style seal collar. FWIW
