Checking trouble code on 12 Pro
skibreeze
I have a 2010-2011 service manual and it says to have motor running with the check engine light on and press and release the select button on the cluster or the set switch on the left hand control. This doesn't work on my 12 to engage thediagnostics mode. Is it different on the 12's? and if so, how do I get it into diagnostics mode?
Thanks
Fairly typical failure of exhaust temp probe.
Will want to warranty if possible. Sensor is expensive. Had one fail this year out of three sleds and 6000 miles.
When you replace the ex. probe. It will take about 2 min. of run time to clear the code. Go take it for a spin and light should go out.
They used the same probe since 07 so just swap it out with a dragon there are plenty of them getting parted out since you can not sell them. Save your self $100 bucks
