Check those rollers
What’s your thoughts on the those ZRP roller bearings for behind the spring cup on the secondary’s?
we use them on all of our lighten and balanced clutches...if you ever put a secondary back together with the thrust washers VS with out you will feel the difference in spring bind...Thrust washers are better than then white plastic washers...
