Check engine light
N
newfieassault
New member
2013 SBA 800, starts and operates perfect. When I press on the throttle, the check engine light comes on. Let go of it, it goes away.
I checked the throttle position, made sure the breather was in proper position.Used forced air to get ride of any moisture. Gas line antifreeze.
When i pulled apart the main wiring harness, there was a pin missing inside. Don't know if there is supposed to be one gone or not.
Check your TSS (Throttle Safety Switch) in throttle block, different than TPS (Throttle Position Sensor) on throttle bodies.
No it's actually on the throttle flapper....basically it's a safety device, if you let go of the throttle and it doesn't return to the closed position it will kill the engine
