I have a 2015 that's getting a boondocker tunnel. I also have the 36 front end and it will raise the front a bit with stock shock length as well. after looking at the stock tunnel there is an additional suspension mounting hole down one inch, I bet that's the hole the Axys uses to raise chassis. Wondering if I should use the lower hole since front is raised as well with the 36? this should update similar to the axys geometry, The axy uses a drop chaincase however the smaller drivers sit up higher, Any thoughts
