M
2009,800 assault
where does the chassis ground? been having various problems. motor to chassis is open continuity. latest one is i put in new rebuild and injectors wouldn't open at all. i had an old assembly, so i put that one in and it started right up but would die soon as you moved throttle. with pcv unhooked it will not die, but the upper injectors are not showing that they are opening unless i use the ground from the bottom injectors. i have the bottom ground jumpered to the uppers right now but don't know if that will hurt anything
