whats involved in changing a tunnel on an apex....i know its alot of work but does the motor have to come out??
I don't think the rivet holes are drilled. And mine was installed with pop rivets
Will (Lethbridge Yamaha & Marine) He doesn't work there anymore. Noob can get you his phone #(after the bast#rd gets back from sleddin that is!!Where did you get yours installed??
Are aluminum/aluminum structural rivets strong enough? Does anybody have the specs on what the factory rivets are? Plan on doing the swap within a couple weeks!!
No they are not strong enough,don't even consider them. You need a 3/16" zinc plated steel rivet with a steel pull.
M5
The rivets Chad sends with hios tunnel are quality rivets very expensive and you need a air rivet gun to break them. Also his tunnels are top notch with a very easy install just takes time. they are also almost indestructible except for large cliffs or solid objects at high speed. There are pilot holes to getyou lined up then from there create your own new holes.
Does this type of rivet present a corosion problem - or should I be looking at solid type rivets, like Van Amburg sells
