Changing bushings
COP-OUT
I have a 13 800 pro w/ 163 track. I bought some brass bushing from Indy specialities. Can I replace the plastic bushing while the suspension is on the sled. Without taking the A arms completely off. One bushing at a time. I know I have to take the Weight off the front suspension.
Pretty sure you have to take the A arm off the bulkhead. Then the bushings will slide out of the A arm. Pop in the brass ones. Reinstall A arm to bulkhead. Done.
Arms are simple to remove, FWIW. Just common wrenches. Probably easiest and fastest way to do it.
