Chain Tensioner - Super Quick Question
That's right where you have it. The manual chain tensioner in the Viper/7000 Cat is what you want. Unfortunately that spring is still part of the equation with the manual. there's a thread on here just search for it that shows the install and part numbers needed.
most guys are doing manual chain adjusters, stock one is known to wear, break and not keep adjustment. You can either buy the whole kit or piece it together from the RR snowcross sled. I cant vouch for any, as I have a belt drive but here are a couple examples.
Bikerman: http://bikemanperformance.com/snowm...012-up-arctic-cat-manual-chain-tensioner.html
S.T.M.: http://www.stmpowersports.com/arctic-cat-procross-manual-chain-tensioner/
I wouldn't say "most" I would say a few switched over but most sleds are still stock if you look
That goofy auto adjuster is one part of the sled I've never had a problem with. PITA to install but seems to work. 2600mi have installed the 19-50 gears and 15 wide chain. Wanted to do 20-50 but the chain wouldn't fit.
Im running 20 50, my 90 p chain fits n works great, even tho i was told it wouldn't.
I have STMs tensioner in, never an issue
Maybe would fit on a used chain that has stretched a bit. New chain would not fit 20-50 gears. I tried, it was close but no go.
yes I sure don't miss that auto tensioner also. Go with the manual set up if you got the chain case open very easy takes 15-20mins to do. There is also a thread on it in here. Here is the link to the thread I got part numbers and more pics on there. All the parts are out of the 2014 XF 7000 is what I ordered http://www.snowest.com/forum/showthread.php?t=386162
