Chain tension for a 01 summit
doomama800
Does anyone know what the chain tension suppose to be on a 01 800 summit. Not quiet sure dont want to mess it up
I run my adjuster finger tight and then back off 1/2 to 1 turn out (loose), put the key in it.
I think the set up in my manual for a 98 summit says "tighten the bolt with your fingers only then back off until you can get the cotter pin aligned" Typically on mine this works our to be 1/4-1/2 turn back from finger tight. I know this is not your year sled but I don't think the chain case set up is much different.
When you slip in your key, it still has spring pressure on it anyway.
Thanks guys looks like with some other research i've done that your right tighten until finger tight while rocking the secondary then back off to put in the pin.
