I don't know about you guys, but I would NOT run ATF fluid! ATF is actually a type of hydraulic fluid, not a lubricant, it does have SOME lubricating properties but its main job is to apply pressure to clutches and bands to adjust shift points in an automatic transmission. Thats why most older cars use it as power steering fluid also. I run Amsoil, cheaper than the BRP stuff!
ive always used Castrol Syntech synthetic gear oil! 1/3 of the brp price!
Actually, many manual transmissions use ATF and the only time they fail, is when they run low on fluid. Many transaxles use it in their differentials as well. Many FWD transaxles have chain and gears similar to sleds. I would prefer running a synthetic ATF, but overall a good idea Whitefish. Today's ATF is not your Daddys oil of the 60's.
