CFI-4 Polaris 600/700/800 Turbo Kit
I am selling the turbo kit off of my 07' Polaris IQ 600 which is still on the sled now. I am going to a naturally aspirated build to better suit my riding style so I am selling my turbo setup off my sled. Has a total of about 3K miles on it. I reclocked the down pipe to fit my sled (comes out side of ferring), so it could either be re-clocked or if you want mod the sled it's going on the same way it would fit fine.
Details- It originated as a Boondocker Turbo Kit, it comes with;
-Attitude Fuel controller
-Silber Turbo blow off valve
-Upgraded Turbo Performance Oil Pump
-Turbosmart Manual Boost controller
-GT2860 Ball bearing turbo
-Innovate Powersports Wideband O2 Sensor
-VDO Boost gauge
-Turbo Performance gauge mount.
-Fuel lines and regulator
-Oil Tank
-Elbow and flange from Expansion pipe to weld on your pipe just like from Boondocker with the kit new. (Mine will be cut off)
-All the intake/charge air plumbing/air box.
-Clutching: Helix/spring,weights for 600/700 sleds.
This is a pretty much bolt and go kit with exception to the down pipe and welding the expansion pipe to the turbo inlet flange. It ran strong on my sled set at 8PSI for pump gas but being a flat lander it is just not a good fit for trail riding.
Looking for $1400 Shipped to the lower 48.
Thanks, Dan
2013-12-06_12-46-36_644.jpg 2013-12-06_12-46-44_369.jpg 2013-12-06_12-38-07_743.jpg 20131101_215052.jpg 20131108_194405.jpg
