CFI 4 fix kit PCIII maps?
RMKillR
I've searched and searched, multiple forums, haven't seen any one with maps for the dragons with the fix kit. Are there any out there? Thanks.
Most of the kits we have put on you can do to things. One go back to the 08 flash take box off. There is 5 of them around here running that way with no problem. They have slp pipe and can and one with just can.Two you put the newest flash in and put the slp flash in it for your set up. Hope that helps
yes, i have the original flash on this sled from the dealer. the sled never taken in for reflashes and is still running the non updated head. it runs great now with the map i was running which was the chad O map and i also ran the stoutner map with no troubles. just looking if there was a map around that maybe helped pick up some gains. thank you!
