catwalk/wheelie an 09 rmk????
have a 600 and 700 rmk 155.....see these ski-doo sleds doing catwalks.....is it possible with my sleds to make some adjustments and do this when flatlanding in Saskatchewan and not mountain riding????
Thanks for your feedback!
A lot of it is about snow conditions and suspension setup. If your sled doesn't do it now, try letting out your limiter straps a few notches and softening up the torsion springs in the rear. This will allow for more transfer than your currently getting which will help the sled stand on end. You may have to play around with it a bit.
Tracks and traction definately have an impact but I've had an 09 assault (stiff competition track) up on the rear bumper for 50yrds or so numerous times on flat ground
Ski-Doo uses a lot stiffer track, more like the Assault, so that helps with the thrust. The RMK track tends to fold the paddles over a lot so you will not experience that hard pull you need to keep the front end up in the air.
Look another sask rider!
I find no matter how setup your iq susp is the Skidoo's still tend to walk easier!
A stiff lug is a serious factor as stated
Last weekend it dumped and almost put the city to a stand still
but before then it was completely dry
