Carls 910 Polaris edge compression ratio
J
jim
635
Boise
Just call the service department at Carl's...they are great and will help you out. They put their own twist on a lot of things in those motors....
M
Feb 26, 2014
13
Minnesota
I did, the guy said ah maybe its marked on the dome not sure. I guess I talked to the wrong guy. I could try them again and hope for a better response.
05rmksteve
2,486
1,626
Brainerd, MN
If I remember right mine where marked on the coolant side of the dome. Its been awhile since I've had mine apart.
You might be better off cc them because I know I have 1 set of domes that have been milled so the markings stamped on the domes are not correct.
M
Feb 26, 2014
13
Minnesota
Right on 05rmksteve I appreciate the info! I'll pull my head off and take a peek. I assume I can mill them if they are low compression domes? I only ride it out west and would prefer them to be high comp.
