Carbonsled alpha rail
Rail failed on my 165 858 snopro after about 500 miles, rattled apart because the glue failed. After fighting for warranty, I decided to be the guinea pig for the carbonsled alpha rail. I haven't been able to find much on these things, so I'll review it and answer any questions. First ride on it tomorrow
So many companies make bracing for virtually every square inch of the monorail, I'm surprised it's taken this long for someone to make an entire rail. Looks great. Hope it works out for ya
Carbon skid with titanium bolts are a nightmare better use quart of red picture on bolts. They loosen up on carbon no matter what you do. Need to retighten bolts after every ride. Not joking. Pita
Good to know. I didn't go this route to save weight, I did it for strength. I'm not afraid to swap them all out for steel, I'm not gonna big deal a half pound
Kmod has been making an aluminum rail for awhile.
Not a direct OEM replacement though without changing the whole skid like this is. Also, the Kmod is not without its own plusses and minuses. I'm surprised someone hasn't done a "replace one rail with two" like this carbon one but with aluminum rails.
After trying the Kmod setup in my Ascender Alpha, my next sled will probably have one of these carbon rails and an aftermarket shock package. The carbon rail only saves 1-2lb over stock depending on length, but full bracing front and rear, something like Remer's Renderings, adds 7lb on a 165.
OP- What kind of limiter strap did it come with? Is it adjustable?
In my opinion of using the skid it moves a lot. Flexes twists etc which causes all the problems
Lost a trip cuz of the skid.
I woukd think the kmod or a reinforced stock rail would be a more cost effective option. Kmod skids work well………if you can handle air shocks
The carbonsled rail is cheaper than kmod by about a thousand bucks, it uses the factory suspension. And bracing a stock rail would be cheaper normally, but my rail in particular didn't bend or break. All the glue failed and it just came apart, I doubt bracing would have saved it
Here's a pic of the limiter strap. It's in the farthest forward (loosest) position. You can see the extra bolt holes behind for adjustment. After 70 miles of riding, it seems like it might lift the nose more than stock, but I haven't had deep enough snow for it to be a problem. So far no issues, bolts are all still tight. Even whacked a stump once, no damage
I had to re-tighten bolts in cross shafts all the time on the stock twin rail skid in my 2014. Bolts in my Kmod skids stay tight for the most part. Kmod skinny flexes quite a bit in the rear too. The bolts are larger in diameter, plenty long, and they use lock washers under the heads compared to the stock skids.
Can I ask what riding you were doing @Dennissledpool when it let go on you?
