G
gjp
I did the back portion of the tunnel in a 3M 1080 Carbon Fiber vinyl wrap. I am awaiting B&M boards to complete the project.
The wrap is sold in 60" wide sheets. I purchased 4ft of it to do the rear portion of the tunnel and underside.
Whats needed:
4ft roll of vinyl ($80) [5ft if you want to wrap tunnel front]
bondo squeegee ($3)
heat gun or blow drier
74 - Stainless Steel Zinc coated (p/n:8060-686) ($16)
(32 for bumper, 34 for cooler, 8 for dropouts)
Fairly easy to install. Took about 8 hours
I will take more pics once the B&M boards are installed in a few weeks.
Whats needed:
bondo squeegee ($3)
- remove tunnel roll and gussets, removed bumper, cooler rivets
- I cleaned then wiped down with rubbing alcohol before install
- I recommend removing all decals and using goo-gone. I didn't do this!
- I cutout the dimension and installed top then sides
- Placed 3-1/4" strips on top of cooler for exposed holes. A bitch to get in there and keep it straight.
- Installed the wrap on the rear bumper. Used 3 separate pieces at 4" widths. Installed it before underside so rivet backs are covered (32 bloody rivets + 8 for dropouts)
- Installed the underside
- cutout cooler holes
- Rivet the cooler (34 rivets)
- wrap taillight case and installed
