Carb to efi????
mp_2009
just curious what exactly would i need to go from carb to efi??? im sure it would just be best to buy an efi motor
If you are talking about your 900, you would need quite a bit of stuff. The crankcase is different for starters. On the EFI case it has a separate housing for the stater and flywheel. It uses a larger diameter flywheel which won't fit in the carb case. All the electrical stuff is different as well. The magneto end on the crankshaft is larger too.
I have a complete 03 800 EFI engine if you wanted to swap the whole works. I have everything except a fuel pump for it. Would be interested in your 900 basket case on trade.
i did that exact swap on my king , went from carb to efi,, p.m. for any info you want..
Idcatman1.. how many miles on the motor and how much were you thinkin on the price and i just got my new top end yesterday and i have heard of ppl running 800 bottom and 900 top can this be done and what roughly does it consist of thanks
900kingkitty... did you just buy a complete efi motor and switch it that way?? thanks
ya , i basically bought a wrecked sled from powerhouse utah, and he shipped me what i needed, complete motor, with throttle bodies, ecu, wiring harness.y pipe and fuel tank are all different, swappedit all over and it runs excellent
how much did it cost you to get a wrecked sled
he kept everything else, but i think it was $2000.00 , but i sold my old carbed stuff for the same so basically i was out the freight
case halfs
just put in an offer on some case halfs so if i get them ill stick with the carbed but if not im thinkin im gonna spend the money and go efi will know with in a day or 2 and i also found that my helix is broken damn sled is fallin apart lol
