It starts fine but after turning the choke off a few seconds later it will start to high idle, if you just leave it it will hi idle for a bit then it will die. When it starts to die if you flip the choke lever on then back off it will recover then repeat the hi idle til it dies again. When riding it runs like a champ, probably one of the better running sleds in the group, but when you come to a stop and let it idle the idle hangs at about 3k rpm for a while before settling down. I've just got in the habit of flipping the choke on for sec. to settle the rpms before shutting it down.
The jetting is 40 or 45 pilots, can't remember off hand,(stock is 35) air and fuel screws are both currently at two turns but I've taken them both in and out from there trying to figure this out. Carbs are clean and I've sprayed ether around the carb boots and crank seals to check for leaks with no change in rpm so they should be good. Sled is pushing 4500 miles and I'm wondering if maybe the pump is getting weak and can't pump enough fuel at idle but still flows enough when rpms are up when riding. Had the belly off a week or two ago and pulsation line appeared to be in good shape with no signs of damage. Can you test the output of these mechanical pumps? Does anyone know the specs? Or does anyone have any other ideas to check? Like I said it runs fine while riding its just a pia to baby sit it while trying to warm it up and get dressed in the morning.
Sorry for the long post, just trying to get as much info out as I can.
Thanks for any help
Thanks for any help
