G
gtfoxy
I have a fairly indepth question I am hoping someone can give me an answer to.
I am almost done putting together a 02/03 700 VES Engine for a 03 SKS. I have a set of carbs off a 01 800 XC SP I was going to use.
After doing some research I found the 01 800 carbs utilize a piston valve with a 2.0 cutback and a J8-9EFY02-61-3 Jet needle in the 3rd possition.
Begining in 01 the VES 700 and subsiquent 02+ 800 VES utilize a 1.5 cutback piston valve and a J8-9DFH10-57 jet needle (800s were in the 3rd possition, 700s in the 2nd).
All of which used the same P-8 Needle Jet, so that is a constant.
Also, a change from a .7 Long Pilot Air Jet in the 01 800 carbs to a .9 Long Pilot air jet in the 02+ VES 700/800 carbs.
I understand the 2.0 cutback will allow for a leaner air fuel ratio at part throttle than the 1.5 (provided the same needle is being utilized) but I am not familiar as to the metering differences of the different jet needles.
It appears for some reason, depending on low speed fuel delivery of the J8-9DFH10-57 jet needle, they wanted to richen up the VES engines a tad. Or perhaps this needle has a lesser flow at lower openings and they compensated by allowing less air to enter at these throttle openings, thus maintaining the desired 14:1 A/F ratio.
My question lies in, can I utilize these carbs with a needle change to the correct J8-9DFH10-57 needle while still utilizing the 2.0 cutback piston valve, making a change to the correct main jets for my altitude? Or can I increase the main jet and live with it being a little fat at the top end to keep it from baking a cylinder at part throttle? However, a leaner midrange and subsiquent slightly longer plug life and perhaps snappier throttle response would be nice.....
Or another option, leave the jet needles that came with it in, drop them to the 2nd possition and use the VES jetting differences for the 700/800's as a guide as to how to jet for this 700. (I have heard some say they actualy think the non-ves's felt more snappy down low, granted that could be purely a qualitative analogy, but given this apparent calibration difference it may be somewhat accurate.)
Do the VES' require a more robust mid range fuel map for something like valve cooling or lubrication?
Is the change from a 1.5 cutback for the factory calibration to a 2.0 cutback going to make that much of a difference? Or is it so much of a difference I should just sell these and start with 01+ VES Carbs with the proper cutback, needles and air jets? Needles and Air jets are relatively inexpensive, but piston valves are not.
I will try and see if I can compare the needle charts at the dealer tomorrow to see where the metering differences between the Jet needles really are.
Any advice would be greatly appreciated!
