Carb boots for 2006 RMK 600
GoHiSK1
Help Help .
Working on a 06 RMK 600 .
The carb boots are delaminated .
Polaris says backordered and no date for delivery.
The aftermarket does not list carb boots for the 2006 RMK.
Any one have any helpful hints.
Was thinking i would try the aftermarket 2007 boots and see if they will work.
Even if the boots have a different angle and the air box will not fit i could add some foam filters to get this sled back on the snow.
Boots
I have 2 2006 600 Carburated Sleds.
These use flatslides like any older VES motor. Don't know about the Bolt Pattern.
So in 2007 Polaris built a Carburated Shift 600 HO. I believe those boots should fit.
I also believe in later Cargo sled models they kept the 600 HO Carb motor as late as 2009.
Carb Boots
I would call Stones Big Boys Toys in Ogden UT. When I look them up in my system, it shows they have a couple. You can reach them at 801-782-6125. Pat number you are looking for is 5412169, and they are the same on all the carbureted 600's from 05-09.
That is the airbox boot. I believe he wants the carb adapter boot on the engine side.
I have looked up the carb boot part #'s off of the Polaris website.
Part #1253566 is only good # for the 2006 not sure what makes it so special :)
Part #1203447 is for the 2007 through 2009
Part # 1253423 is good from 2000 to 2005.
going to try a set of aftermarket boots from a 2006.
Thanks to everyone for all your susgestions.
Polaris parts came through in the crunch :)
Carb boots where back ordered to Mid March but Feb. 25 a set showed up at my local polaris dealer . I am Happy Happy !!!
Sled is out of my shop and into owners hands just in time for Big $$$ Poker Rally.
Thanks to all that posted the helpful suggestions.
