Glad this thread is helping people!
Sledneckskier. your problem sounds the same to all of ours. So what i;ve gotten from this thread is that, a bog from 5-8k can be caused by any of the following
DPM solenoid- Remove the hoses and sensor and clean assy. with a safe cleaner
Rave Valves and Solenoids- Tear down, clean and inspect. Take caps off raves and the bellows should pull in upon start up, and when reving it out, they should push out. 3D RAVE tests are availibe, search. Check ALL hoses and fittings.
Carbs. - test with another set. or tear down and inspect.
Clutches- Primary- remove and disassemble, inspect for worn parts. 07s are known for wearing fast. Clean
Secondary- remove and dissasemble, clean and inspect for worn parts.
*check belt condition and deflection
Exhaust - Inspect for leaks and damage. Seal leaky exhaust flanges, and inspect can for internal problems.
Check all of these if you are encountering problems similiar to above. May or may not be the problem, but if you test all of these, there is a good chance you'll come up with an answer.
Mark
Mark
