ssearle
New member
I've done a laundry list of test to fix this problem with no luck. Here's where I'm stuck now: confirming the injectors and electrical, that tell the injectors to open, are functioning properly.
I had the injectors cleaned and tested. The numbers came back at 512 cc and 524 cc per min. at 20 psi both before and after the sonic cleaning. So bummer that there wasn't an improvement of flow after the cleaning. I can't find the information anywhere as to what these injectors (yellow) are supposed to flow at or if the difference between the two means one is bad or what. The Machine shop that did the test say they both have good spray patterns. GRRRRR!
Also, I'm wondering if there's a way to plug them into the fuel rail and provide power in the system to confirm the electric current is getting to the injectors and opening them fully creating a spray pattern on say a piece of cardboard. Am I loco? I just hate to put this thing back together and have the same issues as when I took it apart, and not fully test everything I can relating to the injectors.
Okay, I'll stop talking... Penny for your thoughts. Thank you for all your help. I wish I had found this site prior to buying the sled. You guys are incredibly nice and helpful.
