I'd really be surprised if that were the case. I don't think there's much difference in the clutches from the previous couple model years and haven't heard anyone mention not being able to rebuild those. Throw the BS flag on that one.
they are rebuildable if you know where to get the parts and have the special tools required to do the job. i think the lock nut is tightened to like 200+foot lbs, sounds like it would be cheaper and easier to send it to rs or just buy another one.
We can rebuild them. On an M8 it is around $150.00 for a new spider, new bushings, new lock nut, and collar. Parts are cleaned and balanced and returned to you looking brand new. PM me if I can help.
I think that they stopped selling parts mainly because it like a TV's sometimes labor is more than new clutch. Yes Eric is right if we go to an 05 06 M7 you can order a spider and its basically the same clutch but the list price on the spider is 170.79 and if you add 1 hour shop time at 75-100 an hour you can almost put a new on on and its all new. I can sell you a new M8 clutch for about 350 witch is about 100 under list.
How you gyus make you spider last? I've changed my spider two times as it has broken after adjusting belt to sheave distance. I surely like set my distance as it seems to be way too big from AC.
So what are tight they should be and what # locktite?
You need to make sure you get all the old loctite out of the threads on both the spider and the fixed sheeve threads.
Use the red loctite. I think red 271. And what I have found is don't be bashful about using it. Put plenty on.
What I believe breaks the spider is if the loctite doesn't hold it tight. The torque of the motor will continue to tighten the spider until it pops as the aluminum spider climbs the threads on the shaft. So agian if it isn't locked down tight it will break over time.
IMO
Thunder
