Can you put a quickdrive back on if you pull the cogs?
Dogmeat
Just wondering if you can put a quick drive back on if you've pulled the cogs .... or do you have to install the cogs first then use the special tool?
if you have to use the tool, anyone know where i can order one at?
When I had the cogs off to change a blown belt, I took the dremel tool to the backside of the splines. Taking the edge off makes getting them started with the belt on relatively simple.
Belt on the cogs, lowered into place all at once. Tape around the center of the belt helps you get the length to slide the assembly on.
I am sure the tools make it even easier.
