V
Hi,
I have two sleds one a 02 rmk 600 and the other a 04 vertical escape 700.
I have done a lot of searching on the correct camber for this sled's and I still do not know the corect setting. I see that most sleds are around 2.25" if you are doing the rod method but I also found a post that had a pdf file showing .82 for a assult. Just try to get the right setting.
Also I will be narrowing both sled's the 600 to about 40" wide and the 700 to about 39" wide should I also change the camber to a lesser amount if they are more narrow. Thanks for your help.
