Hello,
I need some help with a problem that is plaguing me. First, my wifes sled chunked a piston last year, 2005 Trail RMK. I had both cylinders bored .020 over. I inspected the condition of the other parts. Everything looked good and so pop in a set of Wiseco with new rollar bearing and clips. everything when back together fine. I was pulling 118+ psi on the compression. She recently put 50 miles on it and it died. Well, I had zero psi in the same cylinder as before and thand that piston and cylinder end up toast. I inspected the oil line to that carb and it seemed fine. I get the feeling that the cylinder is not getting lumbrication. Oh I did have the hose off that blow pipe fmistakenly for a short time while starting it up after the new pistons were in. Once I re-connected it it ran like a real champ, that is unitl it bit the dust.
Any help would be greatly appreciated.
Thanks,
Mark
2008 700 Dragon
2003 700 RMK
2005 Trail RMK
Thanks,
Mark
2008 700 Dragon
2003 700 RMK
2005 Trail RMK
